Scandal size?
Scandal size?
6 Users
1 Reactions
I am smack on the cross over size for a On One Scandal, 5'7 which is minimumhieght for a medium and tallest for a a small. Which way do people go? Rode a medium that maybe felt a touch big but that was possibly modern wide bars.
Your thoughts please.Not a big air rider, more a wheel on the ground chap.
Posted : 25/03/2023 5:54 pm
If medium felt big I'd go for a small.
They were originally designed as a small, medium and large. They added the XL after so the small should be the right size.
Posted : 25/03/2023 6:12 pm
I'm 5'7" and I find my daughter's small too short in the top tube for me. My normal bike is a small cotic soul. I'd have a look at the reach of both, and compare them to other bikes you like.
Posted : 25/03/2023 6:42 pm
Thought this was a new report from No 10 in the Sunday papers....
As you were....
Posted : 25/03/2023 6:50 pm
I’m your height and was wrongly sent a small frame. My dropper was a good inch above the minimum insert point.
I have a medium whippet and jack flash.
Posted : 25/03/2023 7:29 pm
Struggling to compare as a apart from a couple of rides on my mates last month I haven't ridden a MTb, let alone a modern one more than a dozen times in a dozen years.
Posted : 25/03/2023 7:30 pm
Well I went for a small.
Feeling a bit unsure now. It seems OK but I have a nagging feeling/worry. Got nothing to compare to really apart from riding that mates medium that seemed a touch long with a 35mm stem and several people commented on this. I think I needed a small and a half. It could go back as its only out of the box. There is a lot of post showing although, again, maybe it is a touch high. But then as a 60 year old who wanted a MTB as he hadn't had one for 20 years. What do I know? Last thing I sat on this week was my TT bike which doesn't help.
No idea how to decide how to size a dropper for it.
Posted : 29/03/2023 7:48 am
I know this will be of no help.
I'm 5'8", 31" inside leg (and older than you 🙁 ).
I have purchased the previous version of the Scandal in Medium, after year's on an old school 26".
I have felt that the top tube was slightly too short, but that could be because the bars are so wide to what I was used to, but overall the bike does feels long.
If small and a half is required, then a longer stem and narrower bars may be better as you can make a smaller bike 'larger', but impossible to make larger bike 'smaller'.
( Smaller allows for more technical riding, than the medium, so it will ultimately depend upon what sort of riding you plan to do.
Regarding dropper post, I went for the 150 drop, and still has room to raise or lower.
Posted : 29/03/2023 10:00 am
Cheers. It is a nippy bike I want as, to me, modern bikes handle like Peter Fonda's chopper.
I have a slightly longer stem to go on. Main worry is if a dropper will fit. Bit a of stumpy leg me so hopefully things hould be ok although knowing my luck it will be the expensive droppers I need.
Posted : 29/03/2023 4:19 pm
