So my machine has arrived!
It’s definitely been used before but in very good condition indeed.
Things it didn’t come with:
Frothing jug*
Filter for the supplied water filter housing
Manual
Water hardness test strip
Single wall portafilter baskets for ground coffee (came with 2 x double wall baskets for whole beans).
Very well packaged indeed.
Initial thoughts coming from a [single button push] Delonghi Magnifica:
Much nicer looking
Very solid
Not as big as I thought it might be
A bit more involved for each brew …. obvs
Milk frothing is really fab
A lot of customisation – but this is good as you can [eventually] tailor your coffee to exactly what you want!
Happy 🙂
* I already had a stainless jug to use for milk but on the first go the machine didn’t stop heating the milk. Afterwards I looked at the jug and the bottom is slightly concave so the machine’s temperature sensor [which the jug sits on] wasn’t making good contact so it didn’t know when to stop.
The next time I moved the jug so that the outside edge was def on the sensor – this time the machine displayed the milk temperature going up and stopped right on cue.
I may buy a slightly smaller jug with a flat bottom.
