I just rebuilt a front wheel (29″ into 27.5″) because I didn’t like mulleting my trail bike. The front hub is a Koozer BM540, 20×110 boost.
Koozer sell several axle converters. So I decided I could use one wheel and two forks on two of my bikes depending on what I was riding using the 20×110 to 15x100mm adapter. Tubeless Assegai fitted, maybe have to adjust the brake caliper when swapping wheel between bikes.
But then I hit a conundrum. My first fork is a 20x110mm boost 200mm Killah DH fork, one dropout side is threaded for the 20mm maxle. The second a 15x110mm 160mm boost Durolux Enduro fork with their snazzy titanium flower headed QR axle .
The hub end caps diameter only fit onto the DH fork. I have no way of using my Suntour axle in the dropout hole.
I just don’t see the point of the axle converter right now, for my forks. I assume I need to build another 15x120mm boost wheel.
What is the point of these adapters? Am I missing something? I couldn’t even use it between a 20x110mm and 15x110mm Durolux because of the end cap issue.
