Yo Dudes
Had a great ride this morning but noticed on the last run that my forks felt odd at over half compression/travel/ They sort of felt a bit graunchy/rough. The top stroke was smooth.
I let all the air out of the postive chamber (120psi) and the forks started sucking down until there was little more than 50mm travel left. Then I let all the air out of the negative chamber (35 psi) and they went back up again but not by that much.
I gave them a yank and can get them to top out but they seem to suck back down a bit by themselves.
Is this normal? I was planning on getting a seal/lower service done but wondering if I should ask the mechanic to look for any issues at the same time.
If these are easy to service I could always have a crack myself – I have the spare seal kit from when they were new.
Cheers!
