Home Forums Chat Forum Rockshox 200hr service Kits .. any cheap sources / alternative options ?
Viewing 5 posts - 1 through 5 (of 5 total)
  • Rockshox 200hr service Kits .. any cheap sources / alternative options ?
  • kaiser
    Seeing the price of what seems to be not a lot I was wondering if folk knew of cheaper sources ( ALIEX etc ok ? ) or advice re what you really need and don’t need …so.. sourcing individual parts either genuine or from such places as general  seal stockists makes sense . Need to save my pennies ! Thanks in advance
    Bill
    1
    bigyan
    Ben at BC Suspension sells aftermarket seal kits a lot cheaper than the OEM ones, he uses WSS seals for the specialist seals last time I spoke to him.
    You can buy standard o rings from a supplier much cheaper if you measure them and can select the correct material and shore, a few “custom” seals need to be OEM or aftermarket specific.
    goldfish24
    Tradeinn.com (same as bikeinn) are fine, low prices, good genuine stuff, just be prepared to wait a couple of weeks for it to arrive – over and above what their website says.
    citizenlee
    You don’t specify which model you have, but this seller on eBay should have you covered (Yari linked as an example):
    https://www.ebay.co.uk/itm/283977147092
    1
    kaiser
    Thanks guys .. I actually have a 2019 boost Pike 29+ B1 which actually seems to be based on the Yari/lyric platform . I’ve been doing a fair bit of detective work as I want to run it at 100mm on a Krampus . Nobody could advise re the airshaft (with confidence ) but finally I seem to have sourced what I need ..namely a DA100 kit ..item number 12.4018.010.244 if anyone is interested.  Not easy to find at a reasonable price unless you are in the states.
