Building up a new drop bar bike. First time I’ve had gear cables coming out of the back of the shifter and under the tape. Last bike was 3×9 with the shifter cable coming out the side of the shifter.
I’ve used electric tape to position the shifter housing and brake hose where I want them, but just how tight are you supposed to make the corner just behind the shifter?
Too loose and I can imagine everything feeling mobile under the bar tape. Too tight and I can imagine creating a lot of drag in the shifter.
Or am I overthinking it and you just go tight as you can with three or four wraps of electrical tape?
