Just checked. Cranks are 50/34. Nine speed
Work out gearing way, tyre size isn’t changing so you don’t need to worry about tyre size.
50/34 – 11/28
= 50/11 = hardest gear = 4.54
=34/28 = easiest gear = 1.21
divide the big ring by what you are using at the back = gear ratio
32/32 = 1, which should be much easier.
32/34 = 0.94, even better.
Must admit, I’ve never actually rode road gearing before. Only reason I’m looking at is is I’m thinking about buying a gravel bike. Road gearing is mental. I think there’s a middle way required inbetween mtb and road. can call it gravel or bimbling about gearing! 😆
1x sounds good to me actually
38/42 is 0.9
36/42 is 0.85
(who cares about top end speed!)
