I have used the lockdown period to get my single speed back up and running. All is fine apart from the XT M775 brakes which have zero stopping ability. I had problems with the original set leaking in cold weather at the callipers, which was sorted with warranty replacement many years ago.
I’ve bled them twice and they are solid when doing that. Replaced pads and liberally sprayed disc brake cleaner around them. Took them for a ride yesterday and even with some good hard braking they just don’t bite.
They aren’t soft as though they need a bleed, but I can pedal with them pulled right on and squealing.
Any other things to try before I go and spend on some new brakes?
