im currently having problems with my stealth dropper. Stopped working altogether but was under warranty. Took it to bike shop, they sent it off for £20 to get it rebuilt. Got it back and started to install it. As i pulled it through the frame, i mustve pulled to hard and the hose came away from the barb that attaches to the bottom of the seat post and all the fluid leaked out. I then decided to bleed it, slowly put it through the frame, set it up, and was chuffed as it worked straight away, then 2 mins later wouldnt work at all. Bled it again, worked straight away, then suddenly stopped. Not sure why, seems like all the fluid is leaking out somewhere.
