Home Forums Bike Forum Replacment Brake Caliper Piston Seals
Viewing 5 posts - 1 through 5 (of 5 total)
  • Replacment Brake Caliper Piston Seals
  • mackenru
    Hi folks
    I’ve come to the conclusion that my Shimano BR-M7120 SLX 4 piston caliper at the rear is very subtly leaking brake fluid which is contaminating the pads & rotor. It’s nearing £70 to replace the caliper but before going to that level of expenditure I’d like to try replacing the piston seals or the pistons & seals if necessary. So where can I get replacement seals?
    tjagain
    Not from shimano.  there was a post the other day with a link to some 3rd party seals.
    cerrado-tu-ruido
    Here’s the link from the other thread for Zee callipers. I do not know if they are the same size seals as the SLX 7120
    https://www.ebay.co.uk/itm/144961057231?widget_ver=artemis&media=COPY
    mackenru
    Thanks, yeah the list of calipers includes mine. They’re from China and seen a few like that. Might give them a pop, nothing ventured nothing gained…
    boblo
    I used eBay seals and the usual transfer port o ring to refurbish mine and they’ve been A1 since. Cost about £3 IIRC.
