Removing Ti anodisi...
Removing Ti anodising
6 Users
I have a set of Ti truss forks made for me by XACD, at the time I had them anodised in an oil slick/ rainbow colour which we can all agree looks *wicked*.
Anyway the time has come to strip it off to raw Ti, I understand this is easy enough and I have done this with drain cleaner and aluminium pedals before. My issue is finding a suitable container to fit the forks in and dealing with a load of acid after.
Any suggestions for a suitable container or method that doesn't involve submerging them would be gratefully received. They don't fit in my sink and my bath is plastic so I don't think that will work.
Truss forks
Posted : 23/09/2023 12:06 pm
Fishtank?  Usually a few going begging on marketplace
Posted : 23/09/2023 12:34 pm
Wrap them in rags soaked with whatever you're using to strip the anodizing. Stand them in a bucket, and periodically pour the fluid over the rags to keep it wet.
Or, maybe wire wool would work. Harder work, but less chemicals
Posted : 24/09/2023 9:40 am
For Ti, it’s usually more about abrasion than the chemicals anyway.  I’d warm them with a heat gun, apply the chemical to a Brillo pad, scratch it into the surface and then use some 1200/800 wet and dry sand paper.
Posted : 24/09/2023 10:47 am
Deleted
Posted : 24/09/2023 12:06 pm
Thanks all, hadn't thought of soaking rags in the acid. I have a scotchbrite pad that I use for raw ti which will remove the anodising but it takes a lot of work.
Posted : 25/09/2023 8:15 am
Why would you want to remove that?
Are you just going for raw ti?
I think they look amazing as they are, also how many sets of ti truss forks in a rainbow anodising are there. Not many.
Are the unique, possibly not, but I can't imagine you are ever going to see another set of those in person ever
Posted : 25/09/2023 8:28 am
