Remive trans X secu...
Remive trans X security skewer without key?
9 Users
4 Reactions
any ideas how to remove these without the key in the bottom corner
Screenshot_20231121_073055_eBay
Posted : 21/11/2023 7:32 am
 kilo
Mole grips or an angle grinder.
Posted : 21/11/2023 7:36 am
Mole grips on which end???
Posted : 21/11/2023 8:08 am
 igm
Screw extractor?  I’d need to see an end shot.
Posted : 21/11/2023 8:10 am
I'm sure I used to have these, are they a pentagonal key?
Posted : 21/11/2023 8:12 am
I think they're a kind of five sided hex bolt.
I'd go with some grips on the "nut" end.
Posted : 21/11/2023 8:14 am
 igm
I’ve looked now.
If you can squeeze the black outer on to the pentagonal socket bolt mole grips will probably work, but check the black outer doesn’t have a texture against the drop out that might mangle the drop out a little (don’t know how you check).
But given I have screw extractors and they’d drop into that pentagonal socket that’s the minimum damage route I suspect.
Posted : 21/11/2023 8:19 am
Torx may help.
Posted : 21/11/2023 8:33 am
 igm
Buy a new key for £3.99
https://www.sjscycles.co.uk/hub-spares/transx-replacement-special-key-for-antitheft-sets/
Posted : 21/11/2023 8:45 am
euain, toby, toby and 1 people reacted
I had similar on a bike that was given to me, managed to wedge a torx key into the bit on the right hand side of that photo and just unscrewed it.
Posted : 21/11/2023 8:52 am
 P20
A bike shops answer was to ram a torx or allen key in
Posted : 21/11/2023 9:31 am
Sorted, knipex pliers on the nut end
Posted : 21/11/2023 3:43 pm
