I must say I thought they were heavier than that, but I don’t have a means of weighing them accurately, and even if I did I’m not sure I could be bothered to fetch the tyres and rotors off.
If I use Stans Crest rims, they should come out at around the 1400g mark, maybe a fraction less.
I’m puzzled by the end cap thing – never done that before. The front hub already has a 24mm axle, so I can’t see how that would work, or am I missing something?
I’ve since come across another possibility for the rear. The Tempest has replaceable alu inserts in the dropouts – Planet X sell them for QR axles, so I could leave the hub alone and adapt the frame. The trouble is Planet X want £30 per side which is pretty much what it’ll cost me to convert the hub. Does anyone know if those inserts are standard items I could buy elsewhere, or are they only available from Planet X?
Thanks all,
Peter
