I use Stans sealant in road tubeless and tubulars, and a few times now I’ve punctured, sealed no problem to continue riding, but the sealed hole can only take so much pressure. So get home and you can only re-inflate to 40-50 psi before the seal fails (I’m talking about really small punctures here, as well – not obvious rips in the tyre).
Do you reckon a different sealant would perform better? Or just a fact of life that tyres run at 80-100 psi will need patching and you can’t rely on sealant to plug holes long term. I use tufo extreme as a repair sealant for tubs and that stuff seems a lot stronger, but it’s only sold in small amounts and is not meant for general sloshing around the tyre use.
