I think I’ve messed up….
Bought an XT Rd 786 rear mech a while back. Got it in Med cage (GS). I think I asked the guys at CRC (When u could still talk to someone on phone), about the right size for running a 1 x 10 set up. I was looking at using a 28 tooth front ring, as I rarely find a need for massive high gears.
I have a used Sunnrace 12-42 (may be 11-42) cassette.
I’ve now seen some info that suggests that it’s not just the equation of 42 – 11 = 31 and therefor a medium cage mech should suffice….but it’s actually about the max sprocket size!!
And this is based on which ‘Model’ of rear mech, not just the cage length/size.
Apparently it’s only the m6000 range (if dealing with Shiamno) that allow x large top sprockets like 42 and above on the rear cassette!
So my RD780, although an appropriate cage length (?) is not the right ‘model’ and won’t get onto the 42T 🙁
Any wisdom amongst you hive of Owls?
