Sikaflex
I’ve got a tube of that somewhere from when I did the skylight, it’s done a good job there. If it’s still squashy when dry then you may be onto something.
I think there should be a rubber foam type gasket to fill the slight gap when the lights in the van
I was expecting that too, that’s what I was orrignally looking on the google to purchase. The right one, where the big problem is, is a replacement lens from a scrappy after I reversed into my neighbour’s wall. The left one, which has a little dampness in but nowhere near as much, is original, or a least was there when I got it and doesn’t have one either. I assumed I had just badly fitted the right one and left a gap somehow which may not have been there when it left the factory.
