Home Forums Bike Forum question – how many hamfisted, spannerphobic STWers does it take…
  • This topic has 45 replies, 18 voices, and was last updated 10 years ago by ton.
Viewing 6 posts - 41 through 46 (of 46 total)
  • question – how many hamfisted, spannerphobic STWers does it take…
  • ton
    and what if you have discs? or want to run a wider tyre?
    Get yer thinking cap on!
    I was just kidding.
    I use a dremmel, dril and cork when fitting mine.
    househusband
    ^ Had some 10mm nylon stand-off spacers for the rear rack.
    PeterPoddy
    Just taken some more pics – Few more ideas for you:
    My inbred with Genesis forks lacked some mounts, or I used the disc bolts:
    \Untitled by PeterPoddy[/url], on Flickr
    This is another old light bracket:
    On the rear I had to clear the traiiler hitch too, note the reversed bolt, inboard mounting if you like!
    Also note, it’s not a disc specific rack either.
    The rear of Mrs PPs Ridgeback was no problem:
    (Non disc rack again)
    The front was spaced out on a longer bolt, using a road calliper brake fixing bolt this time:
    PeterPoddy
    I was just kidding.
    I was being helpful! 😀
    TiRed
    here is no chainstay brace to connect the bottom of the guard to – I ended up bodging something together using zip ties
    You can do the same as PP using a rear seatpost reflector bracket. Langsters don’t have a chainstay bridge either. Annoying but not insurmountable.
    ton
    cheers, muchly appreciated.
The topic ‘question – how many hamfisted, spannerphobic STWers does it take…’ is closed to new replies.
