I’ve just done my first two chain, in a cheap DFF. Melts easily enough, I did about 150C, for about 20 mins with a bit of jiggling.
The MTB chain had been cleaned before, the one off my Brompton hasn’t been cleaned other than a run through an oily rag every now and then.
It seems dead easy but I’m not impressed yet with the finish, it hasn’t (to quote TJ)
The molten wax cleans the chain. It will remove all traces of oil and dirt. the wax will stick to an oiled chain
there’s still quite a bit of gritty stuff on the inner plates (you know, the narrower links)
What do you reckon? Hotter? Longer? More agitation? or is that some of the graphite in the mix, and not grit?
Will run on the MTB tomorrow and see what it comes back like, if necessary do a proper clean and then rewax.
