Home Forums Bike Forum PSA: Worth it for the rings alone……….
  • This topic has 27 replies, 16 voices, and was last updated 11 years ago by IHN.
Viewing 28 posts - 1 through 28 (of 28 total)
  • PSA: Worth it for the rings alone……….
  • timbur
    http://www.chainreactioncycles.com/Models.aspx?ModelID=46021
    Cheap, square taper, fill your boots.
    Tim
    nuke
    Good one…and currently only 6136 in stock 😯
    timbur
    Better be quick then :O)
    Alini
    Make that 6135…..
    Nice PSA, thanks 🙂
    paulosoxo
    False economy.
    You’ll buy these, use the rings, then buy and build a single speed around those two shiny crank arms, which you’ll then replace with something more bling at the end.
    Don’t feed the N+1
    PeterPoddy
    Good PSA, but nobody noticed the £25 Deore HT2 ones they sold a few months ago….. I did. 🙂
    scaredypants
    they must’ve all missed your PSA, peter
    slugwash
    Cheers for the heads up there Tim, I’ve ordered one for the bike I’m slowly building up for my 14yr old son. It’s from CRC though so I look forward to it arriving on my desk in a box the size of a wardrobe 😉
    timbur
    Morning Slugwash dear boy. I hear you’ve bumped into a wee Scottish fella on the roads down your way!
    Should be in Charlestown the second week of Easter. Fancy a beer? I might be able to squeeze a bike in the car given a small amount of encouragement.
    Jerome
    Cheers timbur,
    Ring perfect for my marin rebuild..
    timbur
    Good work mate.
    That Marin needs retiring. She’s an old girl now!!
    mikewsmith
    good only if you need it, other wise expensive and wasteful for a 22t (cranks bin, 40+t bin, 32t bin)
    slugwash
    … a wee Scottish fella desperately trying to keep up with me during his Puffer training on Dartmoor…. 😉
    I’ll probably be in Lewes around Easter so could do a South Downs ride instead/as well 🙂
    bruneep
    strange thing to post. 😕
    Needing new rings for my work bike, they will do just dandy, if fact its a sq taper bb so i’ll just put the chainset on.
    mikewsmith
    lol
    it’s only cheap if you need that exact thing, not many I know running 22/32/42 9 speed. Don’t know anyone on Sq taper at all. If you are stock up though.
    bruneep
    My SQ taper xt BB has been on my work bike for yrs and has been flawless (kiss of death now)
    mikewsmith
    fair enough (I see the who else has one post) I generally never got on with shimano rings either 🙂 there was a PSA on SLX shifters a while back, having tried some I could see why they were cheap too.
    timbur
    Drop me an email. First week we’re here, second week we head SW.
    Jerome
    Burden, i have another Eldridge that has had a slightly better life..
    timbur
    Not difficult. That first once was baggy.
    Rickos
    False economy.
    Don’t feed the N+1
    This is so true. But I can’t help it.
    granny_ring
    What length bb axle for these cranks 113mm?
    falkirk-mark
    Just check if you can that the rings are replaceable as I bought a set of cranks with replaceable rings (photos showed replaceable also) and the cranks turned up as spot welded ones.It was also with CRC, however in their defence when I contacted them they refunded me and told me to keep them FOC.
    Edit looks good
    http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/FC/EV-FC-M442-2527_v1_m56577569830608883.pdf
    Edit again just ordered cheers
    nuke
    Probably. But then maybe not. I base it more on the frame than the cranks. For example, on my Inbred 853, 113mm was specified for the cranks but I found 118mm better suited to the frame
    coatesy
    Looked it up from techdocs for somebody a couple of days ago, think it was 118 or 122.5 depending on chainline requirements, feel free to double check.
    oliverd1981
    I thought the race face respond double chainsets we’re a good deal, y’know, if you have some kind of 21st century bike…
    granny_ring
    cheers coatesy
    Ah, this could be what I’m after for the little lady’s bike, however…
    The rest of the drivetrain is 10spd; if I swap the 10spd rings across to this crank, will the shifting work okay?
The topic ‘PSA: Worth it for the rings alone……….’ is closed to new replies.
