I have tried both firmwares on the pinnacle app but when using it with indie velo i am getting no difference in gears and still need to move through the gears a lot wjen the gradient on tbe course changes.
That’s normal, all the firmware options do it change how abruptly the resistance changes and how it deals with fluctuating power output.
Some people want an unrealistic flat line on the graph which can feel pretty brutal and tends to also mean it overshoots the start and end points of the interval.
Other people want it to smoothly transition to the new power and then react a bit more naturally so if they slack off a second they just reaccelerate gently, not suddenly find it’s a brick wall to climb back upto the setpoint.
I compared the radings from the power on my chainset (4iii) real-time while riding and the 4iii was showing about 10% higher power reading ish. I am thinking of trying another type of trainer program as i am thinking the software in the program itself converts the power readings with its own software.
Crank/pedal based power is always a couple of percent higher due to drivetrain losses. 4iii might be a bit more off because it’s single sided and people are rarely symmetrical so it might just be your left leg is naturally a bit stronger or your right leg is a bit lazier on the upstroke.
Thread resurrection…..Did anyone ever make this work fully with Rouvy?
Not tried it, but was almost tempted to get it out again for the winter after Saturday’s biblical rain!
