Hi,
I recently got a Sonder Camino with 12 speed GRX groupset.
When I originally got the bike the chain was rubbing against the frame when in twelfth gear.
Sent back to Alpkit, apparently the freehub bearings hadn’t been pressed in correctly so the freehub was obviously out of alignment.
Now I’ve had the bike back from Alpkit I have the opposite problem, when in first gear the derailleur is now rubbing against the spokes. Both myself and my local bikeshop have checked over alignment, replaced the mech hanger, adjusted limit screws, etc and it hasn’t fixed the problem.
Before I go back to Alpkit I just want to check if anyone else has experienced similar problems and managed to fix it?
