I’ve never felt that the Hope hubs were “lacking” but I did a quick bit of research and came up with some figures for other high end hubs.
Chris King: 72 points of engagement, 5 degrees between engagement points.
Industry Nine Torch: 6-pawl, 2-phase, 115-tooth drive ring, 3 degrees between engagement points.
Industry Nine Hydra: 6-pawl, 6-phase, 115-tooth drive ring, 0.52 degrees between engagement points
Onyx hubs: uses a sprag system with effectively 0 degree engagement*
*Quite how you can tell between 0.52 and zero degrees is beyond me! 0.52 degrees on a 175mm crank equates to 1.6mm of movement at the pedal
