We’re about to have a new patio built and whilst clearing the area discovered that what I thought for years was a drain cover was actually an outside tap in a hole (hole is about 60cm deep).
It’s deep enough that the digger shouldn’t touch it when leveling the area but I’m paranoid it’ll leak as soon as they’ve finished building so I’d rather disconnect it inside the house.
Problem is the stop tap under the kitchen sink does nothing to it and there’s no other visible pipe in the house. Turning it off at the meter stops it so it’s definitely our supply, but T’d off somewhere between the road and the stop tap in the kitchen (bathrooms etc are all supplied from a pipe that goes from the stop tab back into the concrete floor in the kitchen).
It’s leaked before apparently according to our neighbours but looks like that was the tap as that’s on a new plastic stub of piping so whatever is in the ground is likely 45 years old but currently sound.
WWSTWD?
Leave it for now and maybe rip up the concrete looking for it when we do the kitchen?
If ever it was going to spring a leak it’s when diggers and wacker plates are going over it and pulling shrubs out!
