Seems this is a known issue, the pump opening up while on the frame. The rubber collar that’s meant to hold the handle down doesn’t seem to be a tight enough fit. On my hardtail the other night my pump opened up on every run. On my full suss it’s a much rarer occurrence. The heavy weight of tool in handle will apply a greater force in this regard I guess, but I’m not changing that – it’s half of what the thing is for. It’s a shame because the setup is so good otherwise.
Anyone solved it in a better way than tape? Have I got a duff seal? I replaced it about a year ago, and my replacement one was never better than the original. The issue is now worse than ever.
Another solution that springs to mind is to design and 3D print something in TPU, but that’s an expensive option. Or perhaps a drop of Sugru might supplement the existing seal?
