Hoping someone can give a little advice here.
’09 Mk2 facelift Octavia – 160k miles
2.0 CR140 TDI
Currently having an issue with my Octavia, turned it on the other day and it started juddering badly (little power/struggled to accelerate). The noise/vibration is the same stationary/moving/idle/under load, and doesn’t seem to be affected by being in gear/neutral/clutch in or out.
Fuel was lower than I normally let it go (20 miles remaining) so topped it up thinking it might be crud from the bottom of the tank and that seemed to cure it. Seems to be a red herring though as I think it was the turning it off and on while filling up that stopped the juddering. It’s now done it twice more where a brief on and off stops the juddering and the car drives as normal afterwards, starting from cold.
My mechanical knowledge is limited, but some googling is potentially pointing to a dodgy injector, does this sound reasonable? Anything else I should be checking?
