I don’t know but, given how the spacing shifts the calipers a flat to post (140, no extra spacing) should work to put your Caliper in the correct position for a 160 rotor.
The caliper with a flat to post [140] adaptor should be a direct replacement for a flat Caliper.
Do you have a spare 180 you can check with? Stick a 180 rotor in with your current 160 adapter and, theoretically, it’ll fit there abouts – I wouldn’t ride it but it should look the part of not.
Just does my head in when ever you buy a new bike theres always something different. It shouldn;t be this hard….
In fairness if you bought the whole bike, there wouldn’t be this problem.
The something different isn’t that new, flat mount has been around for a good few years the problem is
I thought I’d be able to use an adaptor to use the post mount caliper I have.
And yeah, old stuff doesn’t always work with new, be that bikes or cars, imperial to metric.
It’s not a bad thing that “we” generally try and get the longest possible life from things but it’s always a bit more complicated trying to make a pile of things with together that are not specifically intended to and that’s always been the case.
