Hi all,
Got another strange one.
Has anyone ever experienced this.
Got a Solaris Max frame I’m building up for a mate. With my fox 32s the superstar headset works fine (tapered steerer).
Move the crown race over to his new pikes I’m fitting and they bind. It appears that the taper on his fork starts about 3 or 4mm higher up the steerer than on my 32s.
It means that the steerer is fouling the middle part of the headset cup as it is inserted.
I’m thinking we need to order a different lower headset cup- probably a hope one.
The current one is a cheapy superstar one.
Is it 100% a steerer headset compatibility issue or could it be the pikes steerer isn’t machined correctly in which case they will need to go back.
I’ve measure with a caliper and my 32s have about 20mm before the taper starts. His pikes have about 23mm. That’s with no crown race fitted.
All of this is with the same crown race and bearings etc.
Anyone seen this before on an ec44/40 lower cup?
