Putoline +1
It’s not even that expensive, that £25 will last forever vs a £5 bottle of dry lube each summer and a couple of bottles of wet lube each winter?
I lost all faith in those water based lubes after someone suggested scotoiler ubs on here. The single most shite bike product I’ve ever spent money on. Left the chain noisy and dry after 50 dry road miles (I.e. a days commuting in perfect weather), required monastic levels of dedication to keep going out to the shed all evening and adding a few more drops to build it up. Then washed off in the first puddle.
And as a spray to protect the frame, it turned a white bike yellow.
At least squirt give you a free sample to find out it’s not much better.
Only downside of putoline is its a PITA to make your drive chain look good. It’ll look good for a few hundred miles but you can’t clean the wax off the cassette without taking it off and soaking it in paraffin. Normal degreasing doesn’t touch it and scrubbing does half a job.
