I tend to ride throughout autumn to spring with varying thicknesses base layers under a 3L layer waterproof jacket. Allows me to vary the airflow and temperature by using the jacket vents and does pretty well at the early morning transition from dark 0 deg to light 8 degrees variability, as I run pretty warm most of the time anyway.
I’m sorted for base layers for below zero and around that. What I’m struggling with is finding something for slightly warmer conditions, the just under double figures riding.
I have a North Face Flight Series crew neck base layer which is pretty perfect, however gets a lot of use and after 10+ years is well past replacement.
It’s very lightweight and thin (see: https://bikemagic.com/cycling-clothing/the-north-face-flight-series-base-layer.html), but also discontinued, and the new lightweight stuff looks a bit too heavy for what I’m after. I guess I’m needing something that wicks very efficiently, but isn’t as thermally efficient as most?
so, STW collective, is there anything that is super thin, long sleeved and non compression?
