Home › Forums › Bike Forum › “Light” trail bikes
- This topic has 62 replies, 39 voices, and was last updated 6 months ago by mildred.
“Light” trail bikes
coconutFree Member
I currently ride a Giant Trance X 29er (150mm Fox 36 front and 185/55 rear). I lightened the bike by putting some DT Swiss wheels on and a Nobby Nic (2.35) on the front. The bike is very capable and generally a fun bike to ride…. but at around 15.6kgs it’s sometime cumbersome, especially when jumping. Are there any “light” weight trail bikes out there that you would be happy to take to a bike park/jumps. Would something like the new Specialized Epic Evo 8 (130mm Fox 34) be the right type, or it it a false dawn in that lighter bikes can’t always stand up to the punishment? I’m 82kgs, so not really hammering the bike too hard.
Modern trail bikes seem to be getting more and more burly and with this comes a weight penalty. I’m looking for something very “playful” that can easily be thrown around and is near to 12-13kgs.
joebristolFull MemberI think the cheaper Transition Spurs come in around that weight – and maybe the standard carbon Stumpjumper (not Evo) might be in that category you’re thinking.
chakapingFull MemberYou’d be looking at moving from a long or mid-travel trail bike to a downcountry or short-travel trail bike.
You probably need to elaborate on what “bike park/jumps” means to you.
Trail centres? Perfect for short-travel shred sleds.
Dyfi bike park? Not so much.
alan1977Free MemberNot sure that bike weight comes into it for jumping
My Banshee Spitfire comes in at 15.2kg as my “big bike” 160/135 27.5
and my carbon Top Fuel comes in at 14.2kg as a downcountry/trail bike.. .could shave a kg with a few upgrades most likely… But it seems to jump better than the big bike, I put it down to the suspension more than anything, not weight… that being said… I feel much more confident on the big bike attempting bigger jumps. The Top Fuel is easier to get off the ground, but in a bike park situation getting off the ground isn’t so much of an issue IMHO.
if I’m going to a bike park I’m taking the big bike, but Top Fuel is definitely solidly built but the geo and suspension doesn’t really lend itself to any get out of trouble moments as the bigger, slacker and arguably more burlier bike
1YakFull MemberIt sounds like your bike is right for you. You could look at weight savings on every component but it would be £££s.
Heavy bikes jump ok anyway. Fwiw I did do a short period of time riding my xc bike (100/120mm) at Rogate. It got down and over stuff, but was scary on the steep stuff and really noodley when pushing hard through corners or landing badly. The 32mm sid wasn’t helping, nor were the thin/light xc rims. Yeah a world cup rider with skills would be fine, but I am a clumsy punter. A heavier trail bike is much better.
nickcFull MemberIt’s probably quicker cheaper and easier to lose a few kilo from you, rather than the bike. I agree bikes have got more weighty, but 29er wheels are heavier, longer forks are heavier, dropper posts are heavier, good tyres are heavier.. It all adds up, and I think I’d rather have all those thing work properly than make them light weight and perhaps not be as reliable.
I put the Epic (even the Evo version) firmly in the XC category personally, I’m sure it’ll take a hammering, but it’s not really for bike park and jumps riding, more your longer distance-as-fast-as-you-can sort of riding.
joebristolFull MemberThinking about it you want that inbetween sort of build kit – if I were going frame only but still wanted something tough enough for hard trail but not DH heavy I’d probably go for:
Fox 34 / RS Pike sort of weight forks. 140mm travel probably.
Frame with 130mm ish rear travel – either light alloy or carbon.
DT Swiss XM481 sort of weight / strength wheels.
Trail casing tyres – this is where a lot of weight / rolling resistance can sneak in.
Thinking about it a Santa Cruz Tallboy carbon might do the job – or even the mullet 5010.
Bird Aether 9c
I think the Canyon Neuron comes in around 13kgs on the lighter builds.
benpinnickFull MemberMy 160mm travel trail/enduro bike weighs 13.5 kg in a set up I would have no issues racing hard on, Ive ridden it at Golfie etc. no issues. Maybe some heavier tyres would add 500g if I wanted super burly.
So yeah its perfectly doable. You just need a light chassis and to choose your parts wisely.
onewheelgoodFull MemberMy Jeffsy is around 12kg but it is a very blingy spec and I think the new ones are heavier anyway. Still at the lighter end of things.
2north of the borderFull MemberThinking about it a Santa Cruz Tallboy carbon might do the job – or even the mullet 5010.
I’ve a fairly top spec Tallboy and despite the short travel, I wouldn’t call it light. Few trail bikes are these days with weight really creeping up over the years. Longer forks with increased leverage on the frame means more material and weight of course. However, I suspect the majority of bikes are seriously overbuilt to minimise warranty claims.
I really miss having a light bike and am tempted by a modern XC machine.
1hardtailonlyFull MemberMy 160mm travel trail/enduro bike (which I suspect is the same as @benpinnick ‘s) is a touch over 14kg. Bird Aeris AM Carbon. XT, Codes, Lyrik, DT XM 1700, Schwalbe Supertrail rubber. It rides light, climbs well, brilliant on the downs. I’d happily pedal it all day. I’d possibly have a second lighter wheelset with lighter/faster tyres for just riding along tyres.
snotragFull MemberAs per @joebristol, , that spec matches most of my recent bikes.
Current gen Fox 34 is plenty stiff and strong enough (much more than the older versions). Pike is similar too, so limit yourself to 140mm front travel and this is bob on. XM4181 rims or 20mm carbon if you have the money.
SC Tallboy, Orange Stage Evo are two great choices. I have raced botn Enduro races and XC Marathons on both my Stage Evo and my current Carbon bold Linkin, both weighed under 13kilo in their lighter guise. Very ridable over long distances but easily strong enough.
I’ve never felt the need to run anything more than EXO casing tyres either (and I do run low at 19/22ish psi too) and this also makes a huge difference as per above.
DaveyBoyWonderFree MemberMy bikes have slowly dropped in weight and travel over the years but seemingly remained just as capable. Currently on a Five Evo with what I’d class as sensibly lightweight bits (Hope/Stans wheels, XTR/XT groupset/Fox 34s/carbon bars etc). Feels far more nimble on the trail as any other bike I’ve ever had – really is a joy to ride.
nickcFull MemberMy 160mm travel trail/enduro bike weighs 13.5 kg
Don’t be shy. Give us the detail, let us critique your choices.
1chakapingFull MemberYou just need a light chassis and to choose your parts wisely.
This, plus a bike with a lively pedal response.
Possibly more important than light weight (but it’s reductive to play them off – aim for both).
benpinnickFull MemberDon’t be shy. Give us the detail, let us critique your choices.
Bird Aeris AM Size ML
MY24 Lyrik Ultimate 160mm
MY24 Super Deluxe Ultimate
Hope Pro5 hubs with Stans Flow Carbon rims
NNic 2.3 Super Trail rear, MM 2.4 Super Trail front *
Shimano XT 10-45 drive with GS mech
RF Era Cranks 165mm
Enduro Maxhit BB
Formula Cura 2 brakes w/ 203/180 rotors
RF Turbine Stem, 35mm
RF Next R Bars, 780mm 20R
200mm Dropper w/Shimano XTR Remote
Ergon saddle
Bird Headset/Seatclamp/Axle*Could have been Maxxis Forekaster 2s when I weighed it.
1joebristolFull MemberThe bike Ben is probably referring to is the Bird Aeris AM – the new carbon one.
1benpinnickFull MemberIIRC we did one with XXSL transmission which was 13kg on the nose but similar otherwise.
1Hob-NobFree MemberAs a confirmed fan of short travel bikes, they are great fun, but if you build them light, they do have their limitations in terms of of reliability, if you are riding tougher & bigger stuff.
We have had 2 bikes that sit right in the ‘downcountry’ genre which is kind of what you seem to want as you have quoted the Epic Evo as an example which have both suffered terminal failures (Spur & Element) so have moved on to slightly heavier built short travel bikes (Top Fuel & V5 Tallboy) which, mostly depending on wheels & tyres are anywhere between 12 & 13kg.
Still great fun & I do most of my riding on one, hopefully just a bit more reliable 😆
chickenmanFull MemberMy Liteville 301 comes in at 13.2kg, has 160 travel and Mallet DH pedals. Crucially though it’s ten years old and runs a 27.5 and 26″ wheel combo. Actually it probably weighs a bit more now that I’ve replaced the ten speed XTR stuff with XT and the Reverb with something reliable.
steve_b77Free MemberMy Jeffsy is around 12kg but it is a very blingy spec and I think the new ones are heavier anyway. Still at the lighter end of things.
I’d love to see that on some scales, given most modern 120mm XC bikes don’t weigh much less in reality.
But back to the OP, when you consider what the bikes like the new Epic Evo 8 are designed to do, and what top level XC racers do on them I’d be surprised if you’d have any issues with one.
Kryton57Full MemberThere’s an 11.3 Kg Scott spark in the classifieds 😝 Stick a 120mm fork on it for the use case described and it’d be a hoot.
2bensFree MemberIf your current bike feels cumbersome jumping then I’d say open the rebound damping up a little.
Subjectively not as much fun but certainly much cheaper than a new bike!
2seriousrikkFull MemberWhat exactly feels cumbersome on jumping?
I get the ‘want a new bike’ thing, I live pretty much in that state of mind at all times, but most of us are kidding ourselves if we think a new bike will fix issues that are more likely to be setup or technique related. Knocking a couple of kilos off your bike isn’t going to make you suddenly fly better – how much really is that as a percentage of your overall bike & rider weight?
1onewheelgoodFull MemberI’d love to see that on some scales
With pedals and a Garmin out front mount. I think the XT 12-speed I just fitted is a tad heavier than the XX1 11-speed that it originally had. It’s marginally lighter than my buddy’s ‘money is no object’ build on a Spur, which surprised both of us.
2JonEdwardsFree MemberSomething of interest to me too. I’m currently on a 15kg light-as-I-can-get-away-with RocketMax. Whilst its a beast descending, its a slug working its way back up. I’m 65kg so its not much less than 25% of my bodyweight.
This was a replacement for a 26″ Rocket (so same travel) which was a 13.75kg bike for a very similar spec. But frame tubes are longer, wheels are bigger and its just so damn fast through rocks, you need to run heavier tyres & rims to avoid constant damage. (The first wheels I put on the RMax lasted a couple of rides before they were knackered)
I’d “like” a sub 13kg ish thing, but that can still run a 150mm+ fork (my hardtail has 140mm on it). I find my current 35mm Helm2 fork on the flexy side, and I doubt I’d be able to drop much weight out of wheels and tyres as I spend most of my time smashing through rocks. I don’t really care how much travel the back end has, but do want nicely slack geo. The rest of the build kit would be (give or take) the same as its all sensibly light, sensibly strong, sensibly not-cheap
I was a bit disappointed to see a Dangerholm full bling weightweenie build based on a Scott Genius was still 13.6kg, and thats starting with one of the lightest frames in class. It feels like its just not possible to do real world thrashable trail bikes that are sub-13.5 unless you live somewhere thats pretty gentle on wheels & tyres.
1steve_b77Free MemberI was a bit disappointed to see a Dangerholm full bling weightweenie build based on a Scott Genius was still 13.6kg, and thats starting with one of the lightest frames in class. It feels like its just not possible to do real world thrashable trail bikes that are sub-13.5 unless you live somewhere thats pretty gentle on wheels & tyres.
This……………
molgripsFree MemberI don’t think you need a light bike to jump. You ride up the ramp and your momentum is what carries you and the bike through the air, regardless of how heavy it is. As above, you might just have too much rebound damping on.
If you go with a lighter bike and you do big jumps you are much more likely to break it. They are heavy for a reason.
tall_martinFull MemberMy trail bike is 16.4kg in light mode.
There is nothing I’d want to go lighter on.
I’ve been trying to shift some weight and have managed 3kg from my middle, slaps (92kg) belly!
I cannot imagine getting to 13.4kg on a bike I’m happy to smash about on.
I had Cannondale scalpel with lefty, full xtr and 26″ wheels. It was light fast and…. Broke a linkage. I was never happy getting the wheels off the ground after that and sold it.
I’d suggest riding more or losing some weight from you. It’s a load cheaper, but doesn’t have that new bike feeling.
2onewheelgoodFull MemberI’m still wondering about that 185/55 tyre on the back of the OP’s bike. That must weigh a ton. Swap it for a 2.4 and he’ll be good.
5labFree Memberyeah cumbersome when jumping means either the bike is set up wrong or you’re doing it wrong. The best jumping bikes I own are my DJ bike and my DH bike, both of which weigh north of 40lbs. My 25lb xc whippit on the other hand is rubbish (and my plastic TT bike its probably significantly worse)
1Hob-NobFree MemberI think I need to borrow some scales from other forum users, some of these bikes are remarkably light 🤔
bikerevivesheffieldFull MemberJust weighed my aeris am 160 with coil shock and 170 lyriks, SRAM AXS, slx brakes, brand x dropper, xm1700 wheels and super trail magic Mary/Hans damp, carbon bars
16.4kg
Size large
chrismacFull MemberI’d suggest riding more or losing some weight from you. It’s a load cheaper, but doesn’t have that new bike feeling.
Do both for double pleasure
BadlyWiredDogFull MemberIt feels like its just not possible to do real world thrashable trail bikes that are sub-13.5 unless you live somewhere thats pretty gentle on wheels & tyres.
Yep, this. The point where the bike gets to contact the ground is where feathery light stuff becomes a limiter. I’m sure you could build decently light, very expensive, carbon-rimmed wheels, but as soon as you stick correspondingly gossamer-light tyres on you’re in for a world of fragility.
A long time ago I built a sub-21lb Maverick ML7 for 24-hour racing. It was fine for all that smooth Malvern, Midlands singletrack, grassiness and endless mud, but if i rode it in that spec on my local Peak District trails, it killed tyres and broke spokes for fun. Or not fun basically. I can imagine that something faster with longer travel would be even worse, as per @JonEdwards above. I guess you can simply back off, but what’s the point of that?
I figure that if you ride anywhere remotely hard on tyres and wheels, they’re the limiting factor. My compromise is to run tough-ish, but fast-rolling rubber with a sensible sort of wheelset and not worry about exploding my wheels and tyres every time I steam into a rock garden. If I were stinking rich I’d probably upgrade the wheels to some spangly carbon set, but I’m not and not particularly convinced either.
I know this arguably a different use case to someone who simply wants a lighter bike for jumping, but unless you’re ET, you’re going to spend at least some time with your wheels on the ground.
nickfrogFree MemberI had a YT Izzo to which I fitted Fox 36 in 140mm. It was still close to 13kgs and was a brilliant trail bike. I sold it as HT works better for me but my Big Al is not lighter.
sharkattackFull MemberJumping ability has nothing to do with the weight of your bike.
nixieFull MemberMy Aether 9 is 15.7kg. Seems on the high side but I struggle to see where weight could easily be dropped, other than swapping the coil shock for air and fitting less robust tyres. I’d like it lighter but not at the expense of reliability.
sharkattackFull MemberOk just out of interest I weighed my trail bike for the first time.
It’s 17kg dead. And that’s with my lighter wheels, fast tyres and no inserts. It does have a coil shock which I’m not willing to lose.
It doesn’t even flinch on jumps.
