Hi all,
I have a few years old KS Lev Ci which was serviced a few months ago by Jungle.
Recently it has been a bit stuck in the extended position when it hasn’t been used for a while but it moves freely after the first drop to get it going again. I didn’t see that as too much of an issue just a bit annoying.
I went for a short ride where everything was fine during and washed my bike but now I am left with a suspension seatpost 🙂 It kind of locks in different positions but there are several centimeters sag with load on. The return is also really violent now.
A bit of a Google points to cable tension maybe but I have taken it off the bike and removed the cable and I can still get the seatpost to squish down. Am I right in thinking that the seatpost shouldn’t compress at all with no cable on?
After that my best guess is return for another service as something inside isn’t right inside but I wanted to check with the hive mind if there is anything simple I may be missing?
Thanks!
