We have bought a bubble pond pump thing and went for the 24volt version for safety. The pump is hardwired to around 3m of twin core cable, at the end is a connector, identical to a Tamiya connector, bit I think they call them Molex. The transformer, that will be in the garage socket, has a tail lead around a foot long, and female plug. The only way to control the pump is the switch at the transformer socket. I did wonder if I could get a suitable IP rated outdoor switch, splice and joint the cable in the switch box, then leave the socket on, and use the switch.
Although, just on for a few hours the other day, the transformer got fairly warm. But, if is isn’t “transforming” ie, the switch is off, there will be no current/voltage flow so no heat?
Thoughts?
