Apologies for the hijack, Lakes Puma, but I was looking at DIY penetrating oil solutions and read this…
As I have a plastic NDS cup, the oil + acetone mix will probably eat through that before it has a chance to do it’s thing on the other side but the results from the tests are interesting. The ‘scientific rusting’ is probably a hard thing to quantify and keep uniform of course.
Recently “Machinist Workshop Magazine” did a test on penetrating oils. Using nuts and
bolts that they ‘scientifically rusted’ to a uniform degree by soaking in salt water, they then
tested the break-out torque required to loosen the nuts. They treated the nuts with a variety
of penetrants and measured the torque required to loosen them.
This is what they came up with:
Nothing: 516 lbs
WD-40: 238 lbs;
PB Blaster: 214 lbs;
Liquid Wrench: 127 lbs,
Kano Kroil: 106 lbs
(ATF)/Acetone mix (50/50): 50 lbs.
This last “shop brew” of 50% automatic transmission fluid and 50% acetone appears to beat
out the commercially prepared products costing far more.
