Home Forums Bike Forum How do I remove this axle?
Viewing 12 posts - 1 through 12 (of 12 total)
  • How do I remove this axle?
  • hunterst
    Hi All
    First post for a while.
    Having started riding again, I went out with my daughter and realised she had grown so much her bike looked way too small for her.
    Managed to bag a Carrera Fury off ebay for £35 – Just needs a clean and a few bits n bobs.
    Was going to take the rear axle apart to clean it but i cant get it apart.
    Thought it would just unscrew – but no.
    How on earth do i get it out?
    Any help would be much appreciated.
    oldnpastit
    Can you see what brand of hub that is? Might be written on the hub shell.
    Probably just pull the end caps off and then pull the freehub off.
    hunterst
    Its a hope hub
    I thought the silver cap on the end of the freehub would just pull off or unscrew.
    It moves around easily but doesn’t unscrew.
    I tried pulling it but it didnt feel like it was going to go – don’t want to cause damage thats going to cost me to fix.
    1
    oldnpastit
    If it’s s hope hub then they do just pull off. But they can be quite reluctant.
    1
    andrewh
    Yes, that will just pull off.
    In the Hope YouTube videos where they do it with a shiny new one they just come off by hand , in real life after being ridden for years they come off with molgrips and a lot of swearing.
    If you can get one off you can usually tap the other one out from behind
    hunterst
    Its an 11-02-xc hub
    relapsed – thanks for the link
    oldnpastit – you’ve got it.
    Just found a really grainy video on youtube too, from 14 years ago showing that the caps do need to be prised off.
    Will have a bash tomorrow
    Thanks again
    hunterst
    Thanks to you too for replying andrewh
    1
    andrewh
    11-02 is the date it was made, November 2002, XC is the model. Might be useful if you’re looking for new bearings, although the number should be printed on them. Hope use a common size, I forget what off the top of my head, generic ones fit fine. They are press in/out too, can be pushed out from behind if you can get the caps off, no need for a puller, and the new ones tapped in with a socket and mallet, or pressed in with a vice if you don’t have a press.
    dyna-ti
    On the freehub end, take a couple of pedros(or other brand) tyre levers, one each side and lever it off
    It will usually lift a little bit first time, reset the levers and try to get it to lift further. It should then pull off.
    Inside the spacer is a little O-ring, this is usually what holds it on tightly.
    Then wrap a cloth around the freehub, as the pawls are on the older type springs and can cause the pawls to fly out.
    Remove freehub
    Holding the hub best you can, use a wooden or rubber mallet(ie the bearing filled type) and give the end of the axle as many wallops as is required to drive the axle out the non drive side side, which will take the bearing out with it.
    Removing the two bearings out the freehub can be a bit trickier, and theres usually a spacer and a large circlip that requires circlip pliers to be removed first to get the innermost bearing out.
    What i normally do from there is  drill a hole through a piece of wood wide enough for the axle to fit through so the non drive side bearing and spacer rests against the wood.
    Take mallet or rubber hammer and wallop the little end projection on the on drive side spacer as this then pushed the bearing and spacer off
    Next, take the now blank axle and put it through the hub till it slides onto the internal drive side bearing.
    Back to the walloping 😀 and this will remove the drive side bearing out the hub, leaving it on the axle
    Next back to the wood and repeat – put axle through hole and give it a wallop and this will remove that bearing.
    You are now left with a blank hub, an axle, 2 bearings, and 2 spacers ready to replace with new ones.
    When it comes to replacing it all you are best buying the Hope bearing drift things(Called a ‘Bearing support bush’- they cost about 8-10 quid a pop, and he hub/bearing support tool/rest- called a ‘nylon wheel support bush’
    I’ve always had a thing about Hope stuff and must have serviced well over a couple of hundred hubs. The above method is what I find works best. It takes me a minute or two to strip a hub completely im so used to doing it.
    I bought this ages ago, and it works exactly as it should. Though i’ve only used Hope, so its handy for me. individual bearing supports are dependent on the hub – bulb, ti-glide,pro2, 4 etc
    Hope Complete Set Of Bearing Tools
    EDIT: As you’ve said its XC, ill take a look and direct you to the exact bushings you need.
    Obviously this is a complete kit for the one hub, but you can buy the tools as separates which can be a bit cheaper., but in all honesty, the hub kit is better economically.
    The nylon support though is a must. Saves the hub getting damaged as you fit the new bearings
    dyna-ti
    Update
    You’re in luck – The XC only used a 6001 2rs bearing so this is the only bearing support you need
    https://www.ebay.co.uk/itm/364571993716?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=EAIaIQobChMIxqiQ57mxhgMV8JpQBh3TVABOEAQYASABEgLi1vD_BwE
    + the nylon support tool
    This exploded diagram will help you with reassembly
    https://www.hopetech.com/_repository/1/documents/XCRearHubExploded.pdf
    hunterst
    Thanks for that info Andrew and Dyna – much appreciated
