Hope hub in track ends, how tight do you do the 8mm bolts up? As far as i can tell from the Hope exploded diagram for the hub the load will be placed on the end caps and then the axle so by cranking it up tight i am not excessively loading the bearings. So on that basis i can errr on the side of tight to avoid any unwanted movement in the rear wheel. By tight i mean using a normal size allen key, not a three foot monster. Wheel is on a bike that is likely to case jumps with regularity (bikes fault, not the riders) and go through some reasonably rough terrain at a fair pace hence why i am keen to get it tight.
