Ok folks – who’s successfully shortened Hope brake hoses?
I’ve just followed the very simple Hope video to do it on Hopetech. Great video – makes it look easy.
But – the process involves ‘peeling’ out the brass insert from the brake hose. All I eventually got after much use of the same size of screwdriver they use (and then some pliers to tug it out) is 1.5″ of the internal clear bit of the hose (didn’t realise there was two parts to hydraulic brake hoses – now I do).
So – I now assume therefore my brakes are goosed, as for 1.5″ of the inner hose to be out at the top end presumably it’s detached from the bottom end.
Why are these things never simple.
Tried the same with the rear brake, can’t get the brass olive out of that one either.
So – two questions for anyone who’s done it.
1 – any tip for removing brass insert?
2 – is my front brake now f’d as a result of hose inner coming out. I’m guessing it is (well in that I need to replace the whole hose now and buy plenty brake fluid)
