Are there any sparkies on here?
I’ve got a device that uses a transformer with a two strand output and a large right angled connection on the end – similar to this one:
https://picclick.co.uk/Replacement-for-12V-120V-15A-125A-10A-075A-401394458109.html#&gid=1&pid=1
The device has to be in a particular location to work properly – and getting the power to it means drilling through 3 x 15cm solid walls. Due to the connector on the end this means 25mm holes to get enough wiggle room.
Rather than destroying the house with massive holes could I snip the end off the cord, poke it through a smaller hole and then use a choc bloc to rejoin the cable?
The output is 12v / 1.5a if that makes a difference.
Thanks in advance for any expert advice.
