Home Forums Bike Forum Help with Hope Headset Please
Viewing 27 posts - 1 through 27 (of 27 total)
  • Help with Hope Headset Please
  • neiloxford
    Hi,
    A bit stuck, got a second hand bike with a hope headset. The silver bit with the cut in it seems to big, any ideas? Its the bit that goes at the top.
    Thanks Neil
    neiloxford
    andyl
    (apologies if I’m stating the obvious) it drops down around the steerer into the top of the upper bearing and should wedge in centring the steerer. Then you fit the upper cover and then spacers/stem etc and it should wedge in so needs to be a bit too big. And you may need to use some the thin metal shims to stop the upper cover seal binding but still sealing.
    neiloxford
    Yeah, but its sticking out 5-6 mm, ca’t see it fitting
    andyl
    do you have the top bearing in the right way up?
    And have you tried fitting the rest on top to push it in?
    neiloxford
    Yeah, looks right up to the point where I put in this bit…the silver bit is 1cm high and i can only get it about 2-3 mm into the bit below.
    druidh
    Take.
    It.
    To.
    A.
    Bike.
    Shop.
    neiloxford
    Yeah, thought I would try here first but i agree it needs to be looked at in person…
    Rich
    Isn’t it supposed to stick out?
    From memory I think it is.
    I’d try fitting the rest of the parts and see if it tightens up properly.
    Look here for reference.[link]
    andyl
    take it to a bike shop for that? pfft
    get a decent pic up and worst case is a new ring for £2.30 or whatever it costs.
    Rich
    andyl
    is that the current one?
    neiloxford
    Ok, pics on way
    andyl
    why have you got what looks like the crown race on top of the top bearing?
    I may have to eat my words about taking it to a bike shop….
    RustyMac
    Ha ha ha brilliant, haven’t seen that done before.
    The bigger shiny silver bit is your lower crown race. Your upper crown race is the matt silver bit.
    What do you have at the bottom of the headset? Between the lower bearing and the fork?
    Take a look at the first link rich posted
    andyl
    That is an older Hope headset, never seen one of those in the flesh but what you should have from the top down (obviously fit from bottom up):
    Top cap and bolt
    Stem
    Spacers
    Upper cover + any seals
    Tapered split compression ring (the bit you are having trouble with)
    Top bearing with inner taper up
    Possibly a nylon spacer on that one
    Top cup
    Head tube
    Lower cup
    Lower bearing
    Crown race (need to be bashed on if not split which I don’t think it was on the older ones)
    Fork crown
    neiloxford
    Have I got it all the wrong way around?
    neiloxford
    D’oh think I get where I have gone wrong ! Time for 15 minutes work in the garage….
    RustyMac
    If you currently have a crown race on your fork steerer it will need to be removed before installing the hope one. Crown races are headset specific.
    andyl
    looking at the diagram above and a pic of an older one I think you should have two sections on top of the upper bearing below the spacers. The newer ones just have one section.
    but that is definitely a crown race you have there – look at the marks from removal.
    One problem is that I thought the older crown races had an o-ring around the outer edge as a seal. Are you sure that’s a hope crown race?
    Lay all the bits out you have in a row and take a picture. (except for the cups)
    neiloxford
    One assembled headset, thank you 🙂
    andyl
    Pics or we don’t believe you! 😀
    RustyMac
    Pics or it never happened !!!!!
    andyl
    that looks a lot better!
    are you sure it’s your bike not a random google image? 😀
    neiloxford
    🙂 Will get some photos up when build all done. I just hope i do not have any more awkward moments 🙂
The topic ‘Help with Hope Headset Please’ is closed to new replies.
