- This topic has 26 replies, 14 voices, and was last updated 6 years ago by nick1962.
Help me update my hi-fi
richmtbFull Member
Hey folks
most of my hi-fi equipment is getting on for 20 years old.
My set up has been for many years an Audiolab 8000CDM and DAX CD-Player, Audiolab 8000S and 8000P amplifiers and B&W CDM 7 speakers.
Its sounds absolutely amazing but as you can imagine it takes up a bit of space and these days its not really getting used to its full potential. (Peppa Pig doesn’t really demand the the ultimate in hi-fi)
Anyway the left channel in the power amp bit the dust last night so I think that’s a sign that its time for a change.
I’m prepared to compromise a bit on audio quality and I’m thinking of just tieing everything together using a surround receiver.
I’ve already got a Yamaha DSP-A5 surround amp, which is now just hooked up in stereo, but that’s at least 10 years old
So my plan is to buy this new Yamaha amp.
All my video sources can connect into it and I’ll be able to reduce the multitude of amplifiers down to a single box.
That leaves the speakers. The B&Ws are great, but they are also pretty big and I think the surround amp might struggle to get the best from them.
Does anyone have any recommendation on more compact speakers? I’d still quite like something floorstanding but ideally one that don’t completely dominate the room.
Ta
Rich
angeldustFree MemberHow much are you willing to compromise on sound quality?
That’s a nice system and you are replacing the amp with something relatively cheap….derek_starshipFree MemberThat sketch from NtNoCN was brilliant.
angeldust – why are you cyber yawning?
beanumFull MemberYou didn’t mention a budget, but I’m very happy with my Dali Zensor 5 floorstanders…
Richer Sounds have them for £550
angeldustFree Memberderek_starship – Member
Because it is posted on every other Hi-Fi thread. Usually to take the piss from an uninterested party, rather than to enjoy the humour….
angeldustFree MemberSomeone will make the ‘hilarious’ directional cable comment any time now…. 🙂
How about some KEF Atmos?
Apologies if I’m missing out on some typical STW hilarity.
Don’t think the amp mentioned is atmos compatible. OP seems to want a 2 channel set up?newrobdobFree MemberIMHO you are a complete muppet if you change those amazing speakers. There ain’t no substitute for cubes!
I’d for something better with the amp maybe this https://www.richersounds.com/tv-home-cinema/av-receivers/yamaha-rxa670-blk.html
newrobdobFree MemberDon’t think the amp mentioned is atmos compatible. OP seems to want a 2 channel set up?
I think he has video sources too….
angeldustFree Membernewrobdob – Member
Both those Yamaha amps probably sound pretty good for 2 channel music. Neither will be great, like your existing set up though.
My point being, why would you recommend an atmos speaker in a 2 channel system? The fact that the amp is not atmos compatible is pretty relevant too though!
newrobdobFree MemberBoth those Yamaha amps probably sound pretty good for 2 channel music. Neither will be great, like your existing set up though.
Not in the same league as this issue but I had a lovely Denon amp which was a stripped down no remote “audiophile” amp (about £250). Sounded ace. Had it for a few years and decided to change it for an Onkyo home cinema amp. Initially it sounded a lot worse but once I’d set it up better (and found the “music optimisation” button) it sounded really good, pretty much as good as the Denon.
Cinema amps aren’t as bad as they used to be for music so getting a nice quality one to match the quality of the speakers should be fine and it gives you surround options and better connectivity for wireless (shudder) and all that other modern nonsense. 😉
richmtbFull MemberMy set up has been more AV focused for a while now so I don’t mind compromising onsound quality for music
Main priority is pulling together all the video and audio sources
Video sources are XBOX, Sky Box, Blu Ray, Mini Snes
Audio sources will be a CD player of some decriptionI (I’m ditching the Audiolab I barely listen to CDs anymore) and digital streaming of some descriptionIMHO you are a complete muppet if you change those amazing speakers. There ain’t no substitute for cubes!
I’m still not sure about changing the speakers but I’m open to suggestions
newrobdobFree MemberI’m ditching the Audiolab
That makes me sad. I’ll take it though!
ampthillFull MemberIs the Op trying for 5.1 or just have some smaller stereo speakers?
I think 5.1 amps do seem better at Stereo now. Well our old one was rubbish but the new on isn’t.
richmtbFull MemberI’m not really bothered about 5.1 (I’ve got the speakers for it but not really the inclination to set it all up). But I want something that I can use to bring all the audio and video sources together.
Stereo with a compact centre might be an ideal compromise
MrWoppitFree MemberI’m prepared to compromise a bit on audio quality
And for that reason, ahm oot…
tjagainFull Memberhave you checked for an internal fuse in the amp – my amp has them for each side of the power amp. Take the cover off and the fuses are obvious
richmtbFull MemberI’ll have a look TJ, but to be honest the separates are already in the back of the cupboard under the stairs and the hi fi shelves have been rapidly commandeered for kids board games and puzzles
I don’t think there is anyway back!
slimjim78Free MemberI went from floor standers to better quality book shelf speakers (B&W CM1) and a compact sub – and I haven’t looked back.
Worth considering if minimal intrusion is a preferred option?Also, I run all my media via a hi-fi amp in a 2.1 set-up. Again, it sounds great, and I prefer this system to running music through an AV amp (of which I am sure there are good options, I just personally want to ensure my music takes preference).
Youtube/spotify/HDR/optical/analogue/Google/Echo/PS4 etc all run through my one amp and I wouldn’t have it any other way now.
Marantz PM6006 – best bang for buck I’ve come across.
Plus there is now a ‘UK edition’, which has me very interested..TiRedFull MemberI went for a modest Onkyo receiver to run a 5.1 system, swapping from my Music Fidelity. Sources are Sony DVD7700 ES for CD and DVD, Sonos connect, Apple TV, a Humax box and a PS4 for BluRay. Now for the speakers. I’m a fan of speakers above all other aspects of a system. So I kept a Sonos Faber system home system with a Rel sub.
You have some excellent speakers. Keep them. Don’t feel sad about the receiver. All of my sources go HDMI into the amp (except the DVD which is component) for up-scaling and dual output to a TV and projector. The improvement in convenience more than offsets the amps performance.
Bigger receivers are available, and the Audiolab amps are favourites for separate home cinema processors. but I like the convenience. I did power the front stereo pair with a Quad 303, and it was nice, but space issues meant it had to go back in the box 🙁
2unfit2rideFree MemberOP, have a look at NAD amps, I used to have one & it was very musical, I got rid of it as they didn’t do 4K & HDMI pass through at the time, they do now. Saying that the Denon that I have now is pretty ok, for music I run a pair of Kef Q5 SE’s, bi amped as I don’t need 7 channels, in the ‘pure’ mode. The Kef’s are a very compact floor stander that will tolerate being placed close to the wall due the shape of the cabernet & being front ported, I do have a stupidly large REL Stadium sub to re-enforce them though 😀
Cheers.CountZeroFull MemberI’m not really bothered about 5.1 (I’ve got the speakers for it but not really the inclination to set it all up). But I want something that I can use to bring all the audio and video sources together.
It would be worth setting up a 5.1 system, then just switching off the effects, which makes the amp 2.1, and if you’ve got bigger front l/r speakers the amp can usually be configured to take that into account. I have a Yamaha DSP-AV1 amp, (I think that’s its designation, I can’t read it from where I’m sat), it’s at least fifteen probably at least twenty years old, and sounds just fine, I have a Cambridge Audio DVD99 player for cd/DVD/DVD-A, a Minidisc and an optical feed from my Mac Mini, and I’m perfectly happy with how it sounds through a set of Sony satellites.nick1962Free Memberthe separates are already in the back of the cupboard under the stairs and the hi fi shelves have been rapidly commandeered for kids board games and puzzles
Put the kids for adoption and get the real hifi back out!
Or alternatively go down for a more modern flexible family friendly option and save up for a stonking great system when your kids have left home 🙂
The Yamaha Musicast route is a good choice-it was recommended by a few on another thread recently – gives you lots of options.Sounds like you don’t necessarily need 5.1 so I’d opt for this https://www.richersounds.com/yamaha-rn602-blk.html or the model up the RN 803d which I don’t think Richer sounds stock.Have a look at a few options, price them up then pop into a richer sounds or another of the mainstream hifi shops ( not the one in the above video) and explain what you’re after. They all stock broadly similar stuff at similar prices with the same prices online .They’re not out to rip you off and do know their stuff so use their expertise.
The topic ‘Help me update my hi-fi’ is closed to new replies.
