@nixie good point, I’m forgetting that Easton will work off a 68mm shell where as RaceFace will space out the 73, even if the shell is 68mm.
My older Turbines are 134mm axle (I’ve some newer ones in 136 which come with a rubberised washer each side). When I went from a 142mm back end to boost, all I did was change the chainring to a 3mm offset.
A 6mm offset should get me back to where I need to be, but I’m struggling to find 6mm offset AND Shimano 12 speed compatible because of those silly chamfered plates. Add to that wanting Cinch and 38T and I’m wondering if I should just buy a new chainset.
