Andyl..don’t know if I’m being thick here ..but did you mean 50k out of Michelins ….?
5k makes them a pretty shit tyre !
5k more than than other brands.
I ended up with Michelin PS4 in the end. Worked out about £40-50 a set more than Eagle F1s. Dunlop RT2’s were in the running too as supposed to be pretty good for rolling resistance.
Replaced the completely trashed P-Zeros on the rear and some wierd “ZTyre” fronts that the previous owner fitted. The fronts still had about 4-5mm tread in the middle but I wanted shot of them and was trying my best to kill them but only managing to scrub the edges down. Horrible noisy things that i had no trust in due to low feel but only a slight bit of understeer to be fair.
First impressions is I kind of miss the P-Zeros, they are standard fit for Mercs and they felt very wide and stiff but very controllable when you wanted to use the torque to kick the back end out on empty roundabouts. I guess that comes from my only complaint with them that they lacked forward traction and I would often wheelspin when starting off or when overtaking on a slighty wet road in sport mode and manually downshifting at around 50mph. The P-Zeros did impress me with their wet grip right down to the limit though, I dont normally let tyres get below 2.5mm but these were completely shot and on the limit across the tyre with the inner edge lower due to the camber. They were at about 3.5-4mm when I got the car I have put exactly 20k miles on them without grannying them.
In contrast the PS4’s feel planted in every direction and I suspect a lot less fun below and up to the legal limits 🙁
