Getting shot of a c...
[Closed] Getting shot of a cold - how??
9 Users
3 days of stinking cold here - snot, snot, and more snot! Decongestants haven't worked, rest/fruit/water haven't, chip shop curry hasn't!! Whats left before i top me sen?
Posted : 13/04/2009 3:48 pm
alcohol - drown the bugger
Posted : 13/04/2009 3:50 pm
Vit c? Ecanasia (SP?). Hot steamy shower to clear the sinuses. If all else fails cut the ends off a couple of bird eye chillis, stick them up your nose and sniff hard. May burn a tad but it'll clear your snot!
Posted : 13/04/2009 3:52 pm
echinacea is good for colds and flu
Posted : 13/04/2009 4:03 pm
just ignore it - it's mostly self-pity...
Posted : 13/04/2009 4:05 pm
its a preventive not a cure tho
simonfbarnes - Member
send me a sae and i will send you some snot, then tell me its self pity!
Posted : 13/04/2009 4:07 pm
boots do an own brand soluble vit b tablet, like berroca (you'll find it on the shelf next to it) but higher dosage and half the price. i find that very good for picking up when i'm run down with the lergy esp one that seems to drag on.
Posted : 13/04/2009 4:11 pm
I'm already familiar with it thanks 🙂
Posted : 13/04/2009 4:13 pm
there is no way of shortening the duration of the infection as its viral. all you can do is symptomatic relief and even that has its problems - decongestants for example give you rebound - it that you are more blocked up once they wear off. Paracetomol, fluids, decongestants before bed
Posted : 13/04/2009 4:31 pm
vit c drinks it is then
Posted : 13/04/2009 4:47 pm
Vit c has been to help prevent but not proven to help shift.
Its all about keeping fluids high.
Posted : 13/04/2009 4:48 pm
Yep, what TJ says. You just gotta roll with it. The whole decongestant thing is a big money making scam for exactly the reasons he says. The more you use, the more you need, etc. Maybe a bit of olbas oil on your quilt cover or pillow if you're trying to get to sleep. But forget over the counter stuff, it's mostly bollocks.
Interestingly enough, I saw an advert for "european antibiotic awareness day" on the back of the Obsever magazine informing people that no amount of antibiotics will get rid of a cold. Nice touch...now tell that to the snuffling masses of lazy-arse dodgers lining up at my GP whenever I trot in for a (of course) genuine complaint.
Posted : 13/04/2009 4:50 pm
