Hi guys, hope you’re all keeping well.
My son has a Jamis Dakar A1;
https://www.vitalmtb.com/product/guide/Bikes,3/Jamis/Dakar-A1,24836
1. the frame it a little small now.
2. if I get a bigger frame I can ride it 🙂
I was thinking of getting a Bird Aeris 120 frame and moving the kit across;
https://www.bird.bike/wp-content/uploads/2018/11/Aeris-120-LT-Tech-Data-Sheet.svg
How painful will it be;
0. Biggest question is will the shock fit? the Jamis has a 120mm travel – RockShox Monarch DebonAir RL, rebound adjust, lockout. The Bird is built for this travel and the Bird Spec sheet says 210×55 metric shock with 30×8 Hardware both ends (designed for Bearing Mounts)
1. I may need a new headset
2. I need to check that the fork steerer length is long enough
3. The seat post is 31.6 so OK
4. Bottom Bracket is OK I think
5. Rear wheel is 142 and not 148 so would need a Problem Solvers Booster Adapter kit. Anyone any experience?
As my son is an infrequent rider, I’m sort of excited that I could have access to this bike as well as my current HT. And the bike will get more use than it is doing now.
Cheers everyone!
