Home Forums Bike Forum Front mech problem..
Viewing 7 posts - 1 through 7 (of 7 total)
  • Front mech problem..
  • RealMan
    OK, I've got a santa cruz chameleon, with 38 and 26 chainrings. I called up santa cruz, and asked them which mech would be best for the chameleon, and they told me to get this one.
    http://www.woollyhatshop.com/view_product.php?id=1183
    However, as you can see, it does not work. The picture shows how the actual metally bit is touching the frame, even though its in the outer ring. So when it comes down and in for the smaller ring, its just not going to happen.
    I went down to my LBS and they were very helpful, and tried out this mech
    http://www.woollyhatshop.com/view_product.php?id=2679
    Which also did not work, for the same reason.
    I've been recommended a dedicated double mech, such as sram double x, or shimano saint something something?
    Will this work? And I already have shimano XT shifters, so would a sram mech work anyway?
    RealMan
    Anyone?
    thomthumb
    need to space it as if you had a 44T – ie move it up. simple.
    nickc
    I use an XT conventional mech on mine, fits fine. Move it up a bit?
    RealMan
    Wont it be too high? The black lines on the orange sticker are where the teeth are meant to be.
    nickc
    Yeah, but that sticker is supposed to line up with a 44T outer ring.
    RealMan
    Yes, youre all right, cheers.
    Had a trained mechanic and a guy whos been tinkering with bikes since before I was born, tell me it wouldnt work. And they both had it right in front of them as well.
The topic ‘Front mech problem..’ is closed to new replies.
