Ravemen PR900 on the fork crown. Road-specific cutoff beam + spot (twin cree)
It has a little button remote I’ve O-ringed on the bars. It cycles the modes/flashes main beam without taking a hand off the bars.
I mount the light from the fork crown using a BBB fork crown bracket.
Wide, bright, far-reaching uniform beam with sharp cutoff (non-dazzling).
Slightly warm colour to the main emitter which also seems to be more effective in fog/cloud than a cooler/blue dazzley beam.
Overall it works much like an automotive/motorcycle headlight. Mounted at the crown it shows up every imperfection in the road. It was a game-changer when I first mounted on the bars, yet Found to be even more effective at the crown. Really happy with it.
First time I’ve used a road-specific beam and after 40 years of cycling on the road I’ve begun to ask why I waited so long! They could really market this thing as a ‘gravel light’ because it seems perfectly suited being a dual-emitter (road + high/trail) and USB power bank (out) function so you can charge other devices from it’s 5200 mAh internal battery even when in use. (Handy if your smartphone is running low etc.
Nicely engineered in an alu housing.
