Front light mountin...
[Closed] Front light mounting options? (Not bars or helmet)
12 Users
Anyone running a road/gravel light on your bike that’s not mounted on the bars?
I’ve been experimenting with fork-crown mount and bought the generic nylon one. It certainly is out of the way and works well on the Longitude, but does throw quite a bit of light on the tyre. It shows the ground/terrain in stark relief though. Moreso than on the bars. I find this perfect for gravel, potholes etc.
However with a fairly heavy all in one unit fixed to it (Ravemen PR) the mount vibrates (vertically) quite a bit under the weight of the light when going at speed over rough ground.
So I’ve just ordered a second different crown-mount bracket as the above bracket mounted on the touring (road) bike interferes with the straddle cable (cantis).
(Stock pic)
This one:
If that doesn’t work (was only £6 delivered), then it looks like finally splashing out on a nice front rack (which I’ve had planned since decades ago) 😋.
Posted : 09/02/2022 6:58 pm
I made one that bolted via spacers to the stem face plate bolts?
Posted : 09/02/2022 6:59 pm
^ I like that idea. Gotta pic?
Posted : 09/02/2022 7:16 pm
That one you've just ordered looks like a spring and that it will vibrate terribly.
Posted : 09/02/2022 7:18 pm
Can the light be mounted to GoPro fixings? (My Moon one has a GoPro mount adaptor).
This opens up lots of options.
Both of my bikes have lights which are hung below 'out-front' GPS mounts. One attached to the bars, another to the stem faceplate. Both using adaptors fitted to GoPro mounts
Posted : 09/02/2022 8:15 pm
Winter road/commuter has the dynamo light mounted to the caliper brake bolt along with the mudguard, if it was a disc fork it would be a tad cleaner but would work the same.
Retro roadie has a lovely bit boss halfway up the fork leg specifically for a front light, I still need to make some sort of adapter for it but the position is a good one...
Posted : 09/02/2022 8:20 pm
I like that Garmin/faceplate solution. Would be perfect for the gravelbeast (at least if they did Garmin adapters for the Ravmen PR 😡)
Retro roadie has a lovely bit boss halfway up the fork leg specifically for a front light, I still need to make some sort of adapter for it but the position is a good one…
Like this?
Unfortunately my tourer is not quite that retro, and so got the 1980s smooth fork treatment! Which gives me yet another excuse to buy that Nitto 😚
Posted : 09/02/2022 9:08 pm
 Aidy
I run a fork crown light on the gravel bike. Means I can usefully use a bar bag when bikepacking. I think it's a better place for light throw too.
I experimented with fork leg mounts, but the amount of shadow thrown by the tyre/rim is a bit disconcerting.
Posted : 09/02/2022 9:23 pm
I have one of these screwed into the mudguard eyelet halfway up my forks.
https://www.sjscycles.co.uk/lighting-spares/black-origin8-eyelet-stub-light-mount/
Works well - can put a big exposure light down there with no drama, great for lighting up country lanes
Edit:
You get used to it on the road / lanes. Not sure I'd be keen on full on dark gravel, would want all my light actually doing something.
Posted : 09/02/2022 9:24 pm
Not sure I’d be keen on full on dark gravel, would want all my light actually doing something.
Completely agree, which is one reason I’m looking at moving to a faceplate mount for the gravelbeast*. The fork crown bracket will be tried for the road tourer until such a time I can purchase a front rack with light-bracket.
* If can find a method. Anyone know what this is and how it works?
@scotroutes
That one you’ve just ordered looks like a spring and that it wil vibrate terribly.
I know unfortunately it’s the only thing I can seem to find that will clear the straddle cable. Will give it a shot and return if unsuitable.
Posted : 09/02/2022 10:22 pm
I'll try n find it
Alu angle and some spacers to pack it out. Was rough prototype but worked....
Posted : 09/02/2022 10:33 pm
 Aidy
You get used to it on the road / lanes. Not sure I’d be keen on full on dark gravel, would want all my light actually doing something.
Well, I had mine mounted off-side (for greater visibility to drivers), I found it really disconcerting for the gutter to be totally blind.
https://www.tredz.co.uk/.Lezyne-Direct-X-Lock-Duo-Mount_111970.htm
Exposure do one too
Posted : 09/02/2022 10:34 pm
Exposure do a stem face plate mount for their QR lights.
I haven't tried one, but if I need to buy another mount at any point then I'll give one a go.
Linky
Posted : 09/02/2022 11:06 pm
Not sure if this helps but I have a quadlock phone mount on my bars which I have added their GoPro attachment underneath. On that I have mounted my Halfords off road light and it’s very sturdy and puts the light exactly where you need it for road or track. I only had to buy a GoPro extension piece to get it in the right place.
Probably not what you’re after but if you’re interested I’ll take a picture.
Posted : 09/02/2022 11:15 pm
Thnks, yeah something like you describe, but pretty I’m sure I’d need an adapter/interface to exactly the cleat which is screwed into the bottom of the Ravemen PR unit. Problem is even if the adapter which I linked works for a garmin mount, my light unit is unsuitable for upside-down mounting as the beam is customised for road use. Suppose I could just use a generic garmin faceplate bracket (like this one below) but upside down?
and then mount the light on the top, using this Ravemen computer adapter:
so at least it’d be away from the bars/cables and centred.
Posted : 09/02/2022 11:42 pm
Something like this is an attractive proposition for my tourer as it also keeps the upwards light-leak away from eyes, also clearing the tyres/wheel so that all the light is presumably where you’d want it (on the roads/rough roads/light gravel, general use)
https://www.swisscycles.com/small-and-lightweight-front-racks-for-bikepacking/
Posted : 10/02/2022 12:04 am
You might find the widget you’re looking for here… Linking to the exposure version here but they have loads of options
https://www.racewaredirect.co/shop/exposure-gopro-mount-large/
Posted : 10/02/2022 7:08 am
What about something like this? I've never used it but could be quite neat solution.
Ali Express
Posted : 10/02/2022 8:58 am
I'm using one of these https://www.sjscycles.co.uk/accessories/topeak-bar-x-tender/
Topeak bar extender
It lowers the lamp height, and is reasonably stable on my gravel bike.
Posted : 10/02/2022 11:39 am
