I’ve been trying to fix a freehub issue I had (wasn’t disengaging and as such would lock when freewheeling).
After rebuilding and a thorough clean (oil used as lubricant so that I could eliminate sticky pawls) I’m getting a double-click when I rotate the freehub. Having a camera inside would be awesome, but it sounds like 2 of the pawls are engaging a few degrees before the 3rd.
The hub is made by KT for Vitus (kt-h5er-2227), I would just throw a new freehub in there but I’m unable to find one that says it’s compatible.
Other that going back to hope and having to re-lace the wheel, any suggestions? Just ignore it?
