Home Forums Bike Forum Flat pedals & pins, help a newbie please
Viewing 18 posts - 1 through 18 (of 18 total)
  • Flat pedals & pins, help a newbie please
  • Saccades
    I’m used to flats but got a pair of those Sam hill oil slick flats and 5 tens cheap thanks to all the PSA on here.
    As a dirty big coward the pins look like they’ll destroy my calf/shin at some point. Do I have to mtfu? Or can I put something more stocking friendly on there and live with, presumably less grip?
    Any advice appreciated, thanks in advance.
    prettygreenparrot
    Just don’t scrape your leg on them!
    I’d expect scrapes to be more likely with punier pins.
    even if you do have scrape you will live. Just a bit uncomfortably for a short while.
    back in the day I used to have some great shin scrapes from the ‘bear trap’ style pedals that were popular in the late 70s and early 80s.
    bikesandboots
    Those are M4 pins that protrude by 5mm I believe, and the protrusion is threaded which grabs onto rubber.
    There is much worse out there; longer pins, M3, thin smooth pins.
    My own pedals have 4mm protrustion. It looks like on yours washers could be used on at least some of the pins to reduce protrusion.
    1
    Rubber_Buccaneer
    Do I have to mtfu?
    Unfortunately this is the answer.  Those pins are relatively friendly, take a look at Hope F22, OneUp alloy or Superstar Nano for something to put the fear into your shins 🙀
    1
    sharkattack
    Now that pedals and shoes are both really good I hardly ever slip off them. I haven’t had a really big shin dinger for years and my calves are scab free.
    Kramer
    When it happens, tell everyone that a shark bit you.
    They are sharp little buggers, I have the same pedals
    Ripped a pair of trousers on them when not actually riding
    Other than that though, with a pair of sticky five tens, my feet haven’t ever slipped off them yet
    oceanskipper
    Supacaz do pedals with relatively smooth pins that are also friendlier on the soles of your shoes.
    fatface1
    As previously noted, the BMX pedals of the 80s were nasty. Modern pedals and modern (sticky) shoes stay together really well. Doing bunny hops etc are probably the most likely thing to separate you from the pins.
    You’ll more likely get your leg scars from riding past bramble bushes and getting sliced.
    4
    kelvin
    You’ll mostly stab yourself when pushing the bike.
    1
    binman
    Or when you are stationary.
    They work really well.
    1
    Northwind
    Or when working on hte bike, I have pedal scars on my head 😛 Riding wise, grippier is better as far as avoiding scrapes, they’ll do you more harm when it happens but it’ll happen less often.
    Saccades
    Cheers all, mtfu it is… 😬
    1
    bear-uk
    I always wear football shin pads that slip over my feet . Although most strikes come from behind when pushing.
    johnners
    I’ve had stitches after a V12 interaction, I got a bit tangled up while crashing. I don’t think they were a particularly aggressive pedal but they had very sharp threaded pins. Bad call by a&e really, there’s very little suitable tissue to get a decent set of stitches in, and they didn’t last long.
    This is FAR more likely though, IME.
    dyna-ti
    Have shin pads fallen out of favour ?
    Ahem cough cough ebike …
    sharkattack
    After making that post 2 days ago, yesterday I scraped my calf along the V12 on my BMX while just sitting around at the track.
    I just spotted blood on the back of my work trousers.
    mashr
    dyna-tiFull Member
    This exact thought went through my head on Saturday just after a rock cracked me on the shin
    Back to pedals… you’ll hit your shins less with grippy ones, just unfortunate that there’s more damage when you do
