Home › Forums › Bike Forum › Flat pedal technique. Once more, with feeling (and pics)
- This topic has 99 replies, 53 voices, and was last updated 12 years ago by chives.
deanfbmFree Member
My vid was really to demonstrate a “strong” good body position, a basis to work from.
You need the strong position to be your natural one, don’t even bother complicating things by trying to work out body position in these losing your feet scenarios if you don’t have this sorted. It is normally around 40f/60r weight bias, with body position that is ready to shift. I would suggest this is right for the pic you put up. Slightly more front weight for turning, slightly more weight bias for solid hits rather than those loose stones.
The pictures you have up are a very poor riding position, try getting some pics where you’re actually rolling around on tarmac or something. The “strong” position is the same regardless of terrain and surface, just modified slightly to account for adjustments.
My feet blow off when i’m in a weak position, as soon as i get back to a good position, problem solved. The weak position creeps in when i get scared.
These loose peaks gravel road descents are just about being really loose, getting in that strong body position and letting/trusting the bike to do what it wants.
GWFree MemberJon – at speed you shouldn’t be steering shallow corners with by front wheel grip you should be doing it through weight shift. same with adjustments of line choice over fast rough terrain.
xiphon – I’d like to see you lift a flat pedal hardtail like you can when clipped in without first pre-loading the pedals.
xiphonFree MemberGW – I can switch between flats and clips, yet the method remains the same. I don’t rely on being ‘clipped in’ to lift the bike off the ground…. that’s very poor technique.
smiffFree Memberyeah you aren’t pushing the front into corners like you do on smooth berms. on rough stuff like that, you’re sorta twisting the bike with your hips and legs. at least i am.
also, more speed helps, above a certain speed things smooth out nicely ‘cos the bike isn’t falling into every crack. i had this down one day, then was rubbish the next because i was tired and tensed up.
i would not go back to spds, that just teaches you bad technique.stevomcdFree MemberIt doesn’t affect flex, but it does affect travel
I’m still not sure why this should be the case? Why can you bend your ankle less with your foot an inch or two further back on the pedal? ❓
messiahFree Member@ chiefgrooveguru
I like this quote from Lee
These days I focus on driving the net force—gravity, braking, impact, whatever—directly into the pedal spindle. (Remember, it’s all about heavy feet and light hands.) That’s working way better.
ahwilesFree MemberJonEdwards – Member
It’s this kind of stuff, flat out I struggle with.
…(nice moody picture of a classic loose rocky peak district desent)…
i see your problem, you’re riding one of the most boring trails in the world.
JonEdwardsFree MemberCGG – good links – especially the first one about foot position. That’s exactly where I’m coming from.
bwaarpFree Memberif you are hanging off the back, you don’t need front wheel grip.
I was informed by Rob Warner I was riding too far over the back once and to shift my weight forward and ride the front more.
Apparently, riding over the back is for mincers and is soooo 2001 :P. Aggressive and over the front Sam Hill style is where it’s at.
Sam….on flats.
and at his all time best
mrplowFree MemberAll the back and forward weighting is very unbalanced. How about just going for the middle with weight through your pedals and keeping it there as you go up and down and round. Bend your arms and legs properly and get your face down into the action. Think yourself now gnarr’d
tracknickoFree Memberhang on was that kye forte on a 29er? the bmx world must be a shitload more accepting these days!
bwaarpFree MemberMr Plow has it right.
The amount of times I’ve seen trail riders hanging over the back, hitting wet off camber roots and coming off beggars belief….as others have said….neutral body position is over the BB about 40 f 60 r
Move your weight around accordingly, some peoples styles are different though so just go with what works. Sam Hill rides flats, yet rides over the front more than a lot of other riders. Cedric Gracia appears to keep his arse over the back wheel a lot more.
chiefgrooveguruFull MemberIf you push your hips back (and down a bit) and drop your shoulders down and forwards, your centre of gravity can remain in the same longitudinal position but it’ll be lower, and because your hips are further behind your BB but closer to it vertically it’ll be easier to drive all the forces (especially the critical impact ones) directly into the pedal spindles.
If I’d ridden that enduro yesterday with Sam Hill’s body position but on my inferior bike and with my immeasurably vastly inferior skills I’d have pulled off a few corners quicker, had fewer moments of sketchy understeer, but also gone over the bars a few times!
bwaarpFree MemberGood point chief.
Another one I forgot to mention, having jumped on the slow rebound bandwagon that a lot of DHers are running…..I’ve started noticing how many trail riders run really really fast rebound to the point they are being bucked back and fourth on trails.
I wonder if this has something to do with some riders inability to get on with flats.
GWFree MemberSlow rebound on the back of a hardtail? That’s pure genius, even for here 😀
bwaarpFree MemberI wasn’t talking about the OP. Just mentioned it as I’d seen a lot of it lately and I’ve seen a few thrown off their bikes because of it.
Smart arse. 👿
buzz-lightyearFree MemberSo all the people saying “more weight on the pedals”. How? Hang off the back of the bike? How do you then get front wheel grip?
Roughly speaking, if your hands are “weightless” on the bars, there is ~40% of your weight acting on the front wheel contact patch and 60% on the rear contact patch. I have been training myself to maintain this feeling of weightlessness on the hands and driving with my feet in most situations. source=Lopes/McCormack I think.
GW’s remark about the long looking fork is interesting, and I’m half way to agreeing with him now [shock]. Looking at the photos, there seems to be too little sag. Sag-plus-rebound is needed to make the wheel track/grip properly. Why not increase sag and then whack-up the compression damping? You may find the improvement in grip and reduction in fork-dive really helps you stay on the pedals, and off the bars. Worth a try innit?
Good luck!
jambalayaFree MemberPossibly you are not putting enough weight on the foot which is wandering, i.e. you are riding with more weight on the “planted” foot, this may just be for brief period as you make an adjustment/ride a feature. I think the heel back angle thing is secondary. You might like to try swapping which foot you are leading with as an experiment.
chiefgrooveguruFull MemberSo how do you pick anything approaching a line if the front wheel isn’t weighted?
Turn from the hips, lean the bike, let the front wheel go where it naturally wants to go based on that lean and bodyweight shift. Only at low speed can you really pick a line with the front wheel, and at that speed grip shouldn’t be an issue. But with all your weight in your feet then as long as you’re not pulling up on the bars your front tyre has about 40% of your weight on it.
davidtaylforthFree MemberIm not reading all of this. But a quick look at the pictures tells me the position of your feet is bang out.
I tend to ride flats with my feet in the same position on the pedals as I would need them for doing any sort of stunt i.e. a hop/jump/manual etc. as this is where they feel comfiest and I feel safest/most confident. This seems to be somewhere in the middle of my foot.
You look like you have your feet in the same postion as you would when riding clips, i.e. on the ball of your foot.
Not got a lot else to add.
chiefgrooveguruFull Memberdt, maybe you should have read this link: http://www.leelikesbikes.com/foot-position-on-flat-pedals.html
Not doubting your skills but you’re neither Macaskill nor Lopes… 😉
davidtaylforthFree MemberYes, you’re possibly best off ignoring my advice. I should aswell. I dont think I actual ride on the arch of my foot at all, I just looked at an old picture of me on the bike and thats where my feet were (they must have moved on the pedals)
I then sat on a bike and riding on the arch of your foot feels bizarre, just behind the ball feels right. (it still looks like your feet are too far forward on the pedals though, apart from in the theird picture maybe?)
bowglieFull MemberI converted back to flats a few years ago, but still clip in for road rides. I’m also very familiar with the descents you’re on about (the Houndkirk-Dore drop used to be on my work-home commute 😀 )
As it happens, I’ve recently given some tuition to someone who was having a very similar problem with their flat pedals. It’s difficult to tell whether you have exactly the same problem without seeing you ride, but the photos give some clues – that a lot of people have already picked up/commented on.
Some experimentation might be required, but you could try:
Feet slightly further forward on pedals i.e. pedal axle in, or more towards, arch of foot (when descending rough ground)
Try getting your hips further back and chest lower – and keep them limbs ‘soft’ 😉
Try dropping the heel on you trailing foot more – might need apply slightly more weight to trailing foot to get same amount of drop as lead foot.
Equipment wise, I’m not a fan of the Tevas for flattie equipped hardtail on rough ground. I use AM41’s a lot, but if I know I’m going down a rough Peak descent on my HT, I’ll go for my ‘clumper’ 5.10 impacts, as the grip is better (also use 5.10 Barons which are v.good).
HTH
chiefgrooveguruFull MemberJon, your feet look about 1/2″ further back on the pedal than mine but it does depend on how much toe room there is in your shoes. Your saddle looks quite high for riding descents hard – if you can get your body lower then you can drive your weight into the pedals more effectively. I was using AM40s before, Teva Links now, not noticed a shortage of grip with either on Vaults.
NB – this is bad: “It sort of works, other than it’s really bloody tiring and it means I’m really tense/stiff and unable to absorb bumps.”
In other words, it doesn’t work offroad, especially on a hardtail! 😉
P.S. I like your taste in bikes! V similar to my weapon of choice.
TreksterFull MemberTry getting your hips further back and chest lower
Reckon you will need to rotate your bars/brakes to facilitate this. Best advice I ever got on trip to Vrbier 😆
Having your brakes pointing downwards means your wrists are rotating/pointing down making it difficult to achieve the desired position^^^^^^^^ imo 💡Rusty-ShacklefordFree MemberI came across this the other day, good video…at least, I thought so. I’m not one to be handing out tips, mind.
Interesting thread so far.
chiefgrooveguruFull MemberLook at that – the server ate two of my posts and them spat them out an hour later. Weird…
Totally agree on the brakes – bring them up so you can drop your wrists/forearms, and move them in so your one finger has maximum leverage.
JonEdwardsFree MemberGah.
Just typed a reply and it’s been eaten.
Weight distribution. Just been for a play in the cellar. The position shown in the pics is pretty much neutral. I can happily let go of the bars completely -very little weight on my hands. This is on a flat floor, so a bit false though.
Brake lever positioning is absolutely fine. I don’t know if the pics make them look too steep, but i’m not straining to reach them even hung right off the back of the bike. I’ve ridden some of the steepest nastiest techiest stuff in Les Arcs and the Peaks on that setup (and on flats), and it works fine.
Fork setup. If anything I think they’re too soft at the mo. (I don’t have my pack on, so add another 10 or 15lb on). I have never been entirely happy with those forks though – either they’re divey or they’re harsh and however I dick around with them I can’t get them right, which is a shame as both my Rebas and Lyrics “Just Work ™”. Currently, they’re soft and divey…
Shoes. I used to have 5:10 Freeriders, but they didn’t last too long, and having a cardboard midsole on an expensive outdoors shoe is just a joke, so I decided to try the Tevas instead. Memory tells me the 5:10s were grippier (could be rose tinted specs though). I do remember long descents where I literally had to unpeel my foot from the pedal. Reluctnat to blow another £70 on shoes.
NorthwindFull MemberThe advice in this thread’s already better than I can give I reckon, so I’ll just stick to this- are you absolutely sure that you’re observing these forms while riding? What you’re doing should be perfectly adequate, seems to me, so it makes me wonder if you’re maybe doing it right while leaning against a wall but then slipping while riding. Maybe, maybe not but it’s a very simple explanation…
getonyourbikeFree MemberSeriously, move your brake levers. You’re asking for advice, so take it!
Rotate them to about 20-30 degress from horizontal. You’ll think it’s all wrong but get out on the trails and it’ll make sense.
bowglieFull MemberSeriously, move your brake levers. You’re asking for advice, so take it!
er…quite brutally put, but having looked at your photos, I have to agree on the lever positioning. IME, the position you’re running is best suited to XC ‘aggressive and over the front’ style riding – good for terrain like Thetford, Sherwood Pines etc. and, as you’ve mentioned it’s perfectly possible to get down virtually anything with the levers in this ‘XC-ey’ position. (I also ran my levers in this position for years before tiltin ’em up).A more DH focussed instructor suggested the flatter lever position to me about 3 years ago, and at first I wasn’t that keen as the levers felt a bit odd when stood up on flatter ground. I was a bit of an old skool ‘elbows out/forearms in line with forks’ rider, so the elbows down position that the flatter levers encourage also felt odd to begin with. However, I experimented with a lever half-way between the two positions, then have gradually ended up mving the levers progressively flatter – I guess they’re now about 25-30 degrees off horizontal.
It really is worth a try – and at least it doesn’t cost anything.
Good luck 🙂
trickydiscoFree MemberA more DH focussed instructor suggested the flatter lever position to me about 3 years ago, and at first I wasn’t that keen as the levers felt a bit odd when stood up on flatter ground
jedi said the exact same thing to me. It transformed my riding. The way he put it was to show me how my weight pushed the fork into the ground if my wrists were on top of the bars… when the levers were a bit flatter my wrist was behind the grips.. this meant it was pushing the bike forwards and not into the dirt. Key difference
(think it’s explained in that vid i posted)
The topic ‘Flat pedal technique. Once more, with feeling (and pics)’ is closed to new replies.
