Home Forums Chat Forum Fiat 500 HELP – Warning light (YELLOW TRIANGLE)
Viewing 20 posts - 1 through 20 (of 20 total)
  • Fiat 500 HELP – Warning light (YELLOW TRIANGLE)
  • iamanobody
    Diesel Fiat 500, 57k miles, fully serviced etc. Does probs 40 miles/day
    Drove fine on Friday – to and from work
    Drove fine on Saturday (only a couple of miles)
    Started up first time this morning but had the yellow triangle warning light on and the radio was asking for the code (like it had lost power over the weekend) – car drove fine and no other warning lights, all bulbs seem to work fine (usually display a message to say a bulb has gone)
    the demister/aircon dials sometimes light up/sometimes don’t when the headlights are on – so potential wiring issue
    Any ideas/where to start looking?
    sobriety
    That sounds rather electrical. I’d start by checking that the battery is hooked up ok,and that it isn’t on it’s way out.
    Beyond that I’ve no idea, hopefully someone here will know, otherwise it’s Fiat forums/Haynes Manual/Multimeter/Auto electrician/£££ o’clock in descending order.
    iamanobody
    Thats my inital thought – battery dying and it was colder than usual last night. Car has been doing good runs but not on Saturday.
    No battery light on tho and the car started immediately.
    ads678
    Handbook Usually gives a general idea of what the warning lights mean.
    bikebouy
    Sounds terminal…
    iamanobody
    Handbook says “general fault” light
    wwaswas
    let’s hope it’s not general fault leading to major overhaul.
    BoardinBob
    RustySpanner
    Try the battery first.
    FIAT original ones are a bit rubbish.
    Our Doblo does this now and then, random lights etc.
    Long run and it’s fine.
    iamanobody
    Thats the plan – cheers
    allthegear
    Having owned a Fiat (well, two Alfa Romeos actually)…
    If it’s electrical, DON’T take it to a dealer – they WILL make it worse.
    Rachel
    iamanobody
    Sooooo looking forward to going home to sort this out 😉
    granny_ring
    I got a good deal on a battery for the punto from eurocarpats on line.
    Got 8% with TCB too
    iamanobody
    looking at the thread on the fiat forum it seems battery related. taking it to the local garage on the way home – can supply and fit a new 4 year Bosch battery for <£100 so seems a good plan if it’s that.
    granny_ring
    £56 at euro? before the discount, just a thought and easy to fit!
    iamanobody
    dodgy battery replaced and also brake light bulb. All fine. Marsh Auto parts in Crookes to the rescue!! £61 inc fitting for a 4 year Bosch battery
    jambalaya
    Was just about to post battery, had similar issue on a Rav4 where car actually ran perfectly well but light would keep coming on (and dealer conveniently for him replaced expensive parts under extended warranty). A search in the internet and a new battery later and never had the problem again.
    bikebouy
    What ? No nuclear explosion ??
    Is disappoint.
    (not really, glad its sorted)
    granny_ring
    Good result OP.
The topic ‘Fiat 500 HELP – Warning light (YELLOW TRIANGLE)’ is closed to new replies.
